Message 1 of 4
Emergency backup phone un-needed extra phones: how best for vulnerable customer to return to BT?
Ahead of switchover, an elderly relative has received 3 Emergency backup phones from BT. She intends to give them all to Openreach engineer when he visits on 3rd Aug, but will the Openreach engineer be able to receive & deal with them? If not, what should she do with them?
3 REPLIES 3
Message 2 of 4
Re: Emergency backup phone un-needed extra phones: how best for vulnerable customer to return to BT?
you may find that when BT realise they have sent 3 to same person that they request the return of the excess with charge if not returned as phone only on loan to you just like rest of BT equipment
Message 3 of 4
Don't give them to Openreach technician.
Message 4 of 4
See link
https://www.bt.com/help/tv/how-to-return-and-recycle-your-bt-broadband-hub-and-bt-tv-box-fo
If you call BT 0330.1234.150 you can request that they send a returns bag out to you.
Make sure you keep a copy of your Proof of Posting and if possible take a photograph of it in case you somehow lose the paper copy.
