Message 1 of 4
Engaged tone and unable to dial out after fitting DV adapter
  • Please assist! I have successfully followed the instructions which came with my DV adapter and I can ring in to my house from a mobile as per before the change to DV. However, I only get the engaged tone on trying to dial out from my landline and it doesn’t work when I ignore that sound. I tried dialling 1571, having viewed that suggestion to no avail. All help appreciated. Am I really paying for this “service”?!
3 REPLIES 3
Message 2 of 4
Re: Engaged tone and unable to dial out after fitting DV adapter
Message 3 of 4
can you connect your phone to the socket on back of hub and see if that allows you to make calls
have you tried going to hub manager then select phone number assuming coloured blue then reset base station and see if that helps
Message 4 of 4
Dear imjolly, Thank you! I connected the master phone into the Hub2 as you suggested. Initially, it failed to work but selecting power off and back on to the phone got everything working normally in that configuration. On trying connection via the DV adapter: eureka! It all works as it should.
My sincere thanks.
