Message 1 of 4
Fax Machine
Hello,
Will my fax machine work with digital voice and if so how do I connect it.  At the moment it is connected to a parallel socket to the incoming line.
3 REPLIES 3
Message 2 of 4
Re: Fax Machine
@myquest
As far as I am aware, fax machines will not work over BT Digital Voice, just as normal modems will not. The analogue to digital conversion would distort the tones sent out by the fax machine. Anyway, who still uses fax these days?
If you are a BT Business user, you need to discuss your options on the BT Business Forum.
https://business.forums.bt.com/
You may find this helpful https://www.3cx.com/pbx/fax-voip/
And https://www.steadfasttelecom.com/can-i-fax-over-voip/
A google search will reveal other options.
Message 3 of 4
Re: Fax Machine
Hi,
BT’s website says fax is in fact supported.
https://www.bt.com/help/landline/digital-voice--will-my-existing-phone-and-fax-machine-still-work
scroll down a bit on this page
regards
Regards
Ryan
If this reply was helpful, please leave a like, or if I answered your question, please click 'mark as answer. Many thanks
Message 4 of 4
Re: Fax Machine
@rsmyth492 wrote:
Hi,
regards
That is interesting. It could however be a bit hit and miss, depending on the equipment.
