Message 21 of 46
Re: Fibre to home and Digital Voice
Dear Distinguished Sage.
Thanks for your response.
1. No, its not in the FAQ's that I read. I followed the link in the original email notifying me about FTTP,
to https://www.bt.com/help/landline/what-is-digital-voice-and-how-can-i-get-it-
And did not, do not, read anything about proprietary.
2. Tell me the FAQ link you refer to pls. I will check it out.
3. I did take the time to go to the local "experts " forum where I carefully explained with diagrams my set up. I could have expected to get the facts here and was **not** told anything about proprietary.  The expert agreed that if my Draytek had VOIP and phone sockets (it does) then that could be a way to get DV over copper or glass.
Message 22 of 46
WSH, thanks for this - I am searching for your details using various search strings and not really finding your specific reply for this . I can carry on searching - but could you pls help me out and send the specific link to yr reply on this.
I am basically assuming / hoping that the HH2 will at a hw level connect ethernet from a LAN port to my Draytek thru its WAN2 port. I'd anticipate that the HH2 LAN will live on an IP address served by DHCP from the Draytek?
As such I would expect that the HH2 transparently passes data to the Draytek, i.e. no data inspection nor restrictions on VPN etc.
Yes I understand DV is a "channel" run over a comms path and that could be copper / VDSL or glass. Many thanks in advance..
Message 23 of 46
See the big yellow message in message 2, paragraph 2 of this thread.
Message 24 of 46
Ahh right those FAQ's   :0).
Not the FAQ's I followed from the link in the BT email then.
What I did was to follow BT instructions from their emails which led to the other FAQ's .
How many FAQ's are there?  How many FAQ's pages are we supposed to see to get the err facts   :0)
Anyway if you can, perhaps you could advise the BT experts on the roadshows to see these FAQ's too, so you're all on same page. If I had been told last thursday at the local gathering with BT experts "DV only works  from HH2" it would have saved a lot of time..
Cheers
Message 25 of 46
Hello, could you please tell me did you have to pay for the hub 2?
Message 26 of 46
The FAQ on this forum were put together by form member @licquorice  and like all members of the forum is just a customer and not employed by BT. While the forum's FAQ are accurate and agreed by the forum moderators they are not the BT FAQ.
Message 27 of 46
@Sue41
This thread has nothing to do with being charged for a Smarthub 2. Please see your own thread.
Message 28 of 46
Hello Sue41,
My situation is that I am currently not using a BT hub at all.
However, going forward, I will have to use the HomeHub2 in order to get a phone service using BT's Digital Voice; (and indeed internet data).
My understanding is that the HomeHub2 would be provided free of charge.
Hope that helps :0)
Message 29 of 46
So I revised my diagrams to reflect my new learnings and using the diag from the start of this messaging chain.. This indicated a 4 port ONT box.. Could I get one FoC?
New queries. Help please to answer these and settle the technical issues.
>Diag 1 - copper wires / VDSL -> HH2= DV+internet
If I keep copper wires /VDSL and use the HH2 for my phone, I can connect the HH2 to my Draytek - but
1) do I use the LAN or WAN2 port on the Draytek?
2) I am not sure how the IP addressing would work with my Draytek - would the HH2 accept DHCP served from Draytek? or do I have to work some static / reservation scheme? Does HH2 allow a static IPaddress?
>Diag2, FTTP -> Using an ONT 4 port -> HH2
 In principle I can connect Draytek to the 4 port ONT (If I can get this of course), or to the HH2 (as before).
3) Presumably better to connect Draytek to the fibre optic modem - right?
4) again, would I connect to the Draytek Wan2, or LAN?.
5) Again will IP addressing work by DHCP from Draytek.
Thanx for reading..
Message 30 of 46
Read message 20
