Message 1 of 6
Flashing Screens on Bang & Olufsen handsets when using Digital Voice
Hello
I've just started to use Digital Voice and I've plugged our Bang &Olufsen PSTN base station into the back of the BT router as instructed by BT. The B&O wireless handsets all work fine except in one important aspect. When the landline is not in use, the screens on all the handsets constantly flash by lighting up, then dimming. It's driving us all mad particularly at night in the bedrooms. Can anyone suggest a fix? I've already tried a filter but without success.
Any ideas would be much appreciated.
Chris-Oxford
5 REPLIES 5
Message 2 of 6
Re: Flashing Screens on Bang & Olufsen handsets when using Digital Voice
Message 3 of 6
If you unplug the base station from the hub do the handsets still flash? Is it only whilst the handsets are in the base station and charging cradles?
Message 4 of 6
Hi
Thanks for your response. Yes, when the base station is not plugged into the hub, the handsets are still flashing. Very odd! They flash even when not in their charging cradles.
Any ideas?
Chris-Oxford
Message 5 of 6
Nope, but the problem isn't with BT if it still happens when disconnected.
Interestingly I have noticed recently that my Panasonic handsets do something similar.
Message 6 of 6
Hi All
Since using BT Digital Voice, my B&O handsets now flash because I realise I'm now receiving missed call and other alerts which I wasn't receiving before Digital Voice was installed. It seems I have much superior  interactive than I had before. Well done BT!
