Message 31 of 45
Re: Incoming call turns handset display to bt logo then to synchronising handset data
The quality of Rechargeable Batteries is as broad, as it's long.
I've a Duracell AA/AAA Charger, I use Duracell Rechargeables.
When firing up a new 'batteries included' item. I change the batteries for a fully charged set, from the off. Charging the supplied set, at my leisure. I keep the cheap batteries for utilitarian household items; changing all the batteries just before Christmas; so, they at least get changed, once a year. Works for me.
Message 32 of 45
Re the original posters comment 'by the time I get to the handset'.... its very easy to change the number of rings until the voicemail answers from the default of 7 rings (21 seconds) to the longest you can make it, 10 rings or 30 seconds and that should help to reduce the need to rush to get to the phone before voicemail kicks in and takes over.
One of the things I do is to turn off the DV handsets and then switch them on again (perhaps every few weeks) using the red power/hang up button. I also reboot my Smart Hub 2 allowing it to stay powered off for 2 mins before switching it back on but not at the same time as I reboot the handsets. To turn the handsets off, hold the red hang up/power button down until the power symbol appears on the phones screen (a circle with a vertical line going through the top) and as soon as that appears, release the button and the handset should power off. You can check its powered off by pressing any number button - the screen should stay off. Doing this, combined with making sure I've allowed my handsets to update to the latest software means I only see the synchronising data message when I turn the handsets on.
It's easy to check the handsets have the latest software under menu -> scroll right to -> phone settings -> select -> scroll down to product info -> select -> scroll down to -> update software -> press ok). The back button can then be repeatedly pressed to get out of the menu options. Scroll just means pressing the respective part of the silver ring shaped button that surrounds the ok button to go in that direction on whats shown. Hope that helps.
Anonymous
Not applicable
Message 33 of 45
@FlyingKiwi
The issue has nothing to do with ring delay & is purely down to duff batteries causing the handset to lose power & try to resync.
Message 34 of 45
I didn't say the problem with 'synchronising data' was due to the rings to answer setting - as I wrote, thats simply in there so people know if they're rushing to get to the phone before voicemail kicks in, that this is adjustable. People may not realise this is configurable unless someone tells them and its very handy for those who aren't as quick on their feet as they once were, to know they can have more time to get to the phone if its needed. Sometimes people don't consider the needs of others may be very different to their own.
My solution to the problem noted is as detailed in the remaining paragraphs (and these ARE solutions - I've currently got both an Alexa and an Essentials phone connected to my Smart Hub 2). As with any complex electronic devices, its a good idea to occasionally turn them off then on again - and as I explained in detail, that doesn't mean unplugging the base stand from the mains as that's only a charger. The same applies for battery care ie take the phones off the cradle and leave them off for a few hours occasionally - to let the batteries discharge somewhat. They don't need to completely discharge and down to one bar on the screen icon would be perfect before returning to the charging cradle.
In short, better management of battery charge state will help. This isn't an issue cased by 'duff batteries' or restricted just to BTs DV handsets though and my well known brand corded phone with a satellite handset also benefitted from occasionally taking its handset off the charging cradle and giving the batteries a little 'exercise'. If the batteries don't get that exercise by being discharged and recharged occasionally, that will shorten the usable life of the batteries but people have a choice in that. Leaving the handsets sitting on the cradle all the time at full charge is the worst thing for battery life but the batteries themselves don't start out faulty or duff, mismanagement of their charge state leads to that.
Message 35 of 45
I have exactly the same problem as many of the complainees. I’ve spent hours talking to BT technical people and have tried everything they offered but the problems persist. I think there is an intrinsic fault in these phones and they need to be replaced with phones that work. What is the point of Digital Voice if it works less well than analogue?
I’ve reconnected my old phones via the router and they work reasonably well.
Message 36 of 45
Glad to read all is well with your corded phone base station connected to the phone port on the back of your hub. This is a perfectly acceptable way to use a Digital Voice line and although this won't get all the features that using multiple DV handsets will eg 'multicall' capability, with regard to the synching data message, rebooting the hub (ideally every fortnight with it being powered off for 2 mins) and the Digital Voice handsets (holding down the red hang up button until the screen powers off - again about fortnightly), really is key for addressing this issue. Although I'd get synching data messages when switching back on the handsets, they'd be brief/non- obtrusive I didn't have any contact details stored on my Digital Voice handsets though, have you? Have you also allowed the DV handsets to update to the latest software/firmware versions? This takes about 20 mins but its important its done if offered.
Message 37 of 45
hi,
I had the same problem, was on bt chat support for 1hr 20mins before they cut me off.  I saw a comment in this community that it was the batteries bt supplied and I needed to buy new ones. It made no sense to me because the indicator showed they had charge. Eventually I asked the question, could it be the batteries if the display said charged, and the answer was yes.
Bought new batteries, the problem went away.
So why do bt support not know this?  Why can’t they tells users their phones display is wrong, that the batteries aren’t holding a charge?
I have since left BT.
Message 38 of 45
Hi, yes I understand it to be the batteries. Beggers belief that BT are not aware ...like you I have had my home phone taken out and no longer have home phone.
Message 39 of 45
The problem is not that the batteries are poor quality, its that people leave them sitting on the charging cradle at 100% charge all the time. With rechargeable batteries its best to let them discharge every now and again - and then put the phone back on the cradle to charge but how many people read whats on page 4 of the manual here available for free on the BT website. The battery charge indicator is cradle reading the battery voltage but if the batteries are damaged due to over charging, this will very quickly drop when loaded - hence why calls may disconnect.
Message 40 of 45
Yes, you are probably right. If its the case iclear instructions should be given on page 1!
