Message 1 of 7
Line Cord Error
Hi,
Ever since changing the phone line across to the WiFi box we can receive calls however cannot make them from the landline as it come up with an error message saying:
Please check the line cord.
We have checked all connections and no change. Please advise.
Thanks,
Gemma
6 REPLIES 6
Anonymous
Not applicable
Message 2 of 7
Re: Line Cord Error
You can receive calls on the same handset that reports the error when calling out? If so that's very odd as the error indicates a lack of a physical connection between the phone & an active line.
Message 3 of 7
Re: Line Cord Error
Yes, that's why I thought it was strange! What do I need to do to change that? Thanks again!
Anonymous
Not applicable
Message 4 of 7
Re: Line Cord Error
The most common cause is cables being mixed up. But if you can receive a call that would seem to exclude that. I can only suggest a factory reset of the Hub using the hole in the back. It needs to be help for a while until the lights flash, could be 20-30s.
If that doesn't work you'll have to try another phone. If that's the same it would suggest that the Hub is faulty. You could of course try another phone before resetting the Hub.
Message 5 of 7
Re: Line Cord Error
Thank you for your advice, I will give that all a go! Thanks for your time!
Message 6 of 7
Re: Line Cord Error
One other thing you can try is plug an ADSL filter (the little matchbox sized one) into the phone port on the router and plug the phone in to this.
The router phone port doesn’t produce 50v like the old PSTN system, Thais may be why your phone doesn’t think it’s plugged in.
Message 7 of 7
Re: Line Cord Error
See https://bt-digital-voice.blogspot.com/p/bt-smart-hub-2.html
Quote " In effect, the Hub's phone socket appears to replicate the output parameters of a master socket, except that the DC voltage on Terminal 2 (B-Wire) is +47.9V with respect to Terminal 5 (A-Wire).  This is slightly lower and in reverse polarity compared with the 50V encountered on a PSTN line.  "
The issue may be due to an incorrectly wired plug, a faulty relay in the hub, or hub internal 50V invertor.
