Message 1 of 3
'Menu unavailable' to change the Ringtone/volume on BT Digital voice handsets
Hi this has been asked before and the thread was closed with no posted solution so I am unsure if it was resolved.   I now have the same issues and have asked the original poster if they ever resolved but also starting a similar thread asking the same question again.
This is the previous thread: I can't access the menu to change the ringtone on ... - BT Community
So asking the question again as follows:
I am trying to access the menu to change the ringtone on my BT Essentials Digital Voice phone - I have two of them.  When I choose the Sounds option, then Ringing option it then says Error Not Currently Available. I've tried resetting the handset, base and factory resetting the router, but nothing works?
Anyone have a solution?
Thank you
2 REPLIES 2
Message 2 of 3
Re: 'Menu unavailable' to change the Ringtone/volume on BT Digital voice handsets
Message 3 of 3
Nope, but the option works for me with firmware versionX42_BT_H30225
