Message 11 of 26
Re: My phone has inexplicably started (approximately 6 months ago) to display WITHHELD number
@beckyjones
I have asked a moderator to assist.
Meanwhile, if you prefix any dialled number with 1470, that will release your number for that call only.
Message 12 of 26
Thank you soooo much.
Message 13 of 26
I’ve just tried that by ringing landline from mobile and it worked! - yay! Thanks so much. If the problem can’t be rectified completely at least I can insert those digits beforehand.
You’ve been a great help.
many thanks. 👍🏻
Message 14 of 26
did you actually go to MYBT as suggested by @Anonymous ?  was withheld number still showing as 'add now'[?
Message 15 of 26
Yes I did thanks. Withheld number is not showing at all only Caller Display, which is on.
Message 16 of 26
@beckyjones
It will almost certain to be an exchange data error, where the incorrect information is held because its not in sync with your account, that its why it needs a proper investigation.
The problem is finding someone who is still familiar with the old exchanges that are being de-commissioned, to be replaced by BT Digital Voice, where the calls are carried over the Internet, and terminate on the BT Smart Hub 2.
I am assuming you are not on BT Digital Voice yet, as that would be a different issue.
Message 17 of 26
No I’m not on Digital voice. I live in a remote area so it’s likely to be old systems. I just can’t understand why this suddenly happened without me asking for it as the system was working as it should until about 6 months ago?
It’s so inconvenient as I need to order Farm feed for the livestock and most companies ignore withheld numbers. I will just have to use 1470 before ringing those numbers until this can be sorted.
Thanks so much for your help though.
Message 18 of 26
@beckyjones
Are you a BT Business Customer?
Message 19 of 26
If you can't resolve it any other way, it might be worth asking to be transferred to Digital Voice. A remote area shouldn't be a barrier, all lines will be transferred to Digital Voice by 2025 anyway.
Message 20 of 26
No a private customer.
