Anonymous
Not applicable
Message 21 of 26
Re: My phone has inexplicably started (approximately 6 months ago) to display WITHHELD number
@beckyjoneswrote:
I’ve just tried that by ringing landline from mobile and it worked!
Is this a typo as it implies you're talking about an issue with a mobile? Otherwise you would have rung the mobile from the landline to test.
Message 22 of 26
Just checking, as the moderators could not help with a business line.
If you are in a remote area, the chances are that your line comes from a small exchange, which its possible that BT want to offload.
Assuming you have a BT Broadband connection, then what @licquorice has suggested, may eventually be the way forward, as that is all software controlled which makes it easier to manage.
Message 23 of 26
I tried ringing mobile from landline but it still says withheld number.
Message 24 of 26
Yes it’s a very remote area. I’m looking at Digital voice now.
many thanks
Message 25 of 26
Hi @beckyjones and welcome to our community.
I'm sorry you're having problems with the calls. I'll be happy to take a look at this for you. I've dropped you a private message so check your inbox and send me over the details.
Cheers
David
Message 26 of 26
Thanks for letting me know we got this sorted for you @beckyjones .
Let me know if you have any other problems.
All the best
David
