Message 1 of 6
Porting a Vonage number to BT
I'm a Vonage VOIP subscriber but just moved house and decided to get a BT landline instead.
I have an active BT Retail number now. I'd like to port my Vonage number to my BT line.
Is that possible if the number I have didn't originate with BT?
If so, how do I do it?
5 REPLIES 5
Message 2 of 6
Re: Porting a Vonage number to BT
Hi @mas1, welcome to the forum and thanks for your post.
It's not a common question but I've found this: Solved: Porting Landline number from Vonage (VOIP) - BT Community
This may be of help for you if you've a BT landline over copper. If you have Digital Voice you would be best to call and speak with us.
Cheers
John
Message 3 of 6
Thanks John. The difference for me is my number was originally allocated to me by Vonage, so it's not part of the BT-owned number range.
In that case, would it still be possible to port that number to BT?
Message 4 of 6
Hi @mas1, if the service with Vonage has stopped then it would be a No.
If the number is still active with Vonage it may be possible to get a number port order placed. There is never a 100% guarantee with number ports.
Cheers
John
Message 5 of 6
OK, thanks. Yes, it's still active with Vonage. I assume I would initiate the port order with BT?
Message 6 of 6
Hi @mas1, yes give us a call and ask for a number port and do come back and let us know how you get on.
Cheers
John
