Message 1 of 9
Pulsed dialling tone
I do not have a call waiting on 1571 or 1572 and I have not diverted my incoming calls. Why do I have a pulsed dialling tone on Digital Voice?
8 REPLIES 8
Message 2 of 9
Re: Pulsed dialling tone
Message 3 of 9
possibly a message on 1571
Message 4 of 9
I believe you will find that I stated that I do not have calls waiting on 1571 or 1572 .
Message 5 of 9
I understand call waiting something different hence why I suggested someone may have left you a message
Message 6 of 9
I apologise for using the wrong terminology. I have no messages waiting on 1571 or 1572.
Message 7 of 9
Welcome to the Community @SueFM 😊
Is everything working with your calls as they should be outside of the pulsed dialling tone?
Also if you haven't already, can you try leaving yourself a message, listen to and delete this, then see if the tone returns to normal?
Peter
Message 8 of 9
Thank you Peter.
That has indeed solved the problem.
Message 9 of 9
Cheers @SueFM 😊
Occasionally this can just get stuck if there's been previously deleted messages, so I'm glad this has righted everything!
You take care,
Peter
