Message 1 of 9
Question BT Store
I bought these house phones on the 8th Feb 2021, from the BT Store.
Over the past 9 months or so there has been a crackle on my landline and I have had many BT engineers over the past few months.  The last engineer came at the end of October 2022, again they could not find a fault on the line.
I then contacted BT again to say there was still a crackle on the line and they reset the line.
On the 7th November 2022 I contacted BT again to say there was still a crackle on the line, BT said since the engineers were unable to find a fault on the line the problem is with my handsets.
My question is, I bought these handsets from BT store on the 8th Feb 2021.  But since I have been having a problem for the past 9 months and BT have only now told me the problem lies with faulty handsets would BT store replace my faulty handsets?
8 REPLIES 8
Message 2 of 9
Re: Question BT Store
The problem isn't with your handsets. From your other thread, you are having problems with your broadband due to the noisy line. Noisy handsets would not cause your broadband problems.
There is clearly a line fault that Openreach seem incapable of rectifying
I will ask if the mods can assist
Message 3 of 9
Thanks for reply.
Did you get any answers?
Message 4 of 9
Hi @andreaferns120472, you were offered help on your Other Thread by @RobbieMac
Cheers
John
Message 5 of 9
unfortunately not 😞
Message 6 of 9
Yes you were, you need to reply to the PM sent by RobbieMac
Message 7 of 9
Robbie, I replied to your personal message did you not receive this?
Message 8 of 9
The moderators deal with requests for help on a first come first served basis. Once your request reaches the top of their work stack they will contact you. They are very busy so it could be a couple of working days before that happens.
Message 9 of 9
Hi @andreaferns120472, I've checked, and your PM is in our queue and one of the team will be in touch as soon as we can.
Cheers
John
