Message 1 of 10
Unable to make or receive calls
I received an SMS this morning from BT saying that my Digital Voice is now ready to use.
I rebooted the Smart Hub 2 and paired the Handset, but it just came up with Unable to make or receive calls, a lot of options don't function as it reports 'no internet' on the handset.
Furthermore, I then tried rebooting the router again, resetting the handset, ran through the online troubleshooter but to no avail.
Any suggestions?
Edit: forgot to mention it's the Advanced phone with Alexa
9 REPLIES 9
Message 2 of 10
Re: Unable to make or receive calls
Message 3 of 10
If you go to hub manager is your phone number shown to suggest DV is active?
Did you try a factory reset by pressing recessed button on back and holding for 20/30 secs until lights flash
Message 4 of 10
By Hub manager, do you mean the Smart Hub 2?  As I don't see anything at all on there regarding Digital Voice apart from a gray not configured phone icon, which makes sense as it doesn't connect via the port but WiFi
I reset the hub, registered the handset again, which was successful as always but still the same message shown
Message 5 of 10
The phone does not connect via Wi-Fi, it uses DECT from the home hub.
Message 6 of 10
So why does it use WPS?
I thought the DECT was just between the base and the phone
Message 7 of 10
WPS button, dual purpose. Your BT DV has not been configured.
Message 8 of 10
The grey icon means that Digital Voice has not been activated, nothing to do with any connectivity of your devices.
Message 9 of 10
It shows as activated on the BT App plus the SMS said it was activated, it took about a week to switch over from analogue
Message 10 of 10
Regardless of what MYBT shows or text says if the phone number is greyed out and not configured then DV will not work and you need to phone FTTP TEAM 08005874787 and see if they can help
