Message 1 of 3
Re: Digital voice
Anybody else lost internet and landline after plugging in to BT's "new and improved" digital voice? Its broken my hub & BT now have no contact with any human in dealing with faults - just text after circular text. Just AI robots ...... USwitch beckons .....
2 REPLIES 2
Message 2 of 3
Re: Digital voice
I moved your post so you can get replies to your problem as thread you posted on was marked as solved
moving to DV should have no effect on your internet connection.  do your have FTTC fibre to cab and copper to home or FTTP fibre to home?
Message 3 of 3
Re: Digital voice
The only connection that should have needed moving was the phone plug moving from the wall socket to the green socket on the back of the hub.  Nothing else changes.
