Message 1 of 4
Re: Help with Digital voice - very few incoming calls can dial in - BT runaround
Nothing has changed - I've had no incoming calls since 30.3.22, it's now 11.5.22.  Even though my number was originally a BT number, the problem started as soon as the number was switched.  The DV service worked initially with the new number BT  supplied but failed completely on switching.   So the lesson is to put up with the trouble of not having a familiar number and DO NOT ask for for a number change.
3 REPLIES 3
Message 2 of 4
Re: Re: Help with Digital voice - very few incoming calls can dial in - BT runaround
Message 3 of 4
I moved your post to start your own thread so replies will apply to you and not the other thread originator
What happens if you phone your number from mobile
If you dial 17070 what number is repeated?
Message 4 of 4
From mobile I get line busy. From 17070 I get the number registered on the phone.
