Message 1 of 7
Registering Premium phone
I don’t think I’m stupid but…. (I have removed/replaced the batteries)
I am trying to register the DV phone to the EE hub. On the manage my phone page the following is displayed-
Status  Service ready
Last registered 8/7/24 1151
Handsets
No handset registered.
Start registration -done-nothing comes up on the phone to guide through the steps.
I also can’t find anything in the FAQs as to how to back up my contacts.Any help appreciated.Thanks
6 REPLIES 6
Message 2 of 7
Re: Registering Premium phone
Message 3 of 7
try this link in FAQ
https://community.bt.com/t5/Archive-Staging/Advanced-Digital-Phone-with-Alexa-Contacts/m-p/2188966#M...
there are numerous other posts about saving contacts using search
Message 4 of 7
Tks. The situation is that I have manually added my old contact numbers to the new phone and now need to back them up. All the solutions appear to use web-based solutions- how do I back up the numbers that are stored on the phone/hub.
Message 5 of 7
Hi @JEFFEN57   The only solution is web based through the Hub Manager.  Note if you have moved to EE then you should be using the EE community.
https://community.ee.co.uk/t5/Digital-Home-Phone/bd-p/DHP
Message 6 of 7
if you can get your phone to register on the SH2 base then it has a backup facility
Message 7 of 7
Tks. That may be the crux of the problem,the phone doesn’t seem to want to register—-
Handsets
Start registration via the manager -started the process-nothing comes up on the phone to guide through the steps.
