Message 11 of 12
Re: Retain landline number when switching to full fibre with BT
Interesting and thank you for taking the time to explain it. So who do you think should I contact to determine the reason for the non-availability? And if the reason is cost, is it possible for me to break the logjam by offering to contribute towards that cost?
Message 12 of 12
It’s only really an educated guess why seemingly you could order and now you can’t , and short of going down the FTTPod route ( that’s where you contribute towards the build costs ) you probably don’t have anway to offer a contribution to Openreach , and FTTPod may not be available anyway because of the presumably relatively near by native FTTP , and it’s only potentially the ‘last leg’ from  the location of the relevant CBT ( probably on top of an existing near by pole that could be somewhere around 150M away if two carrier poles were needed ) that’s the issue , FTTPod normally provides the infrastructure up-to and including the CBT which you seemingly don’t need.
You mentioned you neighbour already has FTTP , can you post the DSL returns for that address and indicate its relative position to your address (so something like , detached neighbour , same side of road 25M away , tree lined avenue ) , to give ‘picture’ of why they can get FTTP and you cannot .
