Message 11 of 19
Re: Second phone line I know nothing about!
Private line, on my 'usage' chart on my BT home page.
Message 12 of 19
I have just moved to Digital Voice and my account now shows a 0331 number as well as my actual one.
Message 13 of 19
I’m not saying it’s the case , but a temporary number may be used to get DV working , something like for a very brief period the 0331 nunber is your DV number and provided on your hub , on the migration day / as you connect your telephone to the DV port on the router , this  temp number is re numbered to your proper  number , so that 0331 number potentially exists for a few minutes during the changeover period , regardless if it doesn’t ‘work’ and there is no charge for it then it’s hardly worth worrying about
Message 14 of 19
That's interesting.  But why doesn't BT staff know about it?
Message 15 of 19
Sadly I worry because nobody seems to have a definitive answer and strange occurrences often mean scammers at work!
Message 16 of 19
Unfortunately ( in my opinion ) the walls BT Group have to put up between their various units ( BT Wholesale , Openreach , BT Consumer, ) are to keep the regulator and the competition happy , but it means it’s not likely that BT Consumer will ever be given guidance on technical matters , plus as more and more automation is built in to systems ( also keeps the regulator happy )  , if all communication providers simply press a button and their screens ,  button presser has no idea what  happens after that  , but if all CP’s have the same button on the same screen , then no impropriety can happen between BT and the rest of BT Group
Message 17 of 19
@iniltous
I seem to recall this was raised previously and at that time if I recall correctly, the moderation team checked it out and the number was as you have stated about it being a temporary number used for Digital Voice.
Message 18 of 19
It was a thing call BT Smart Talk which allowed you to make VOIP calls on a mobile billed to your landline.
See; BT SmartTalk lets you make calls from your smartphone on your BT landline account
Richard
Message 19 of 19
Ok, thanks.
Just daft that BT staff are unaware lol.
Think I will close this question then.
