Message 11 of 21
Re: Transfer of Telephone Number
Yes it’s the same. Don’t understand why they are saying this 🤔
Message 12 of 21
Possibly the advisor is getting confused and assuming its the same as with PSTN, where you could be on a different number range.
Only a moderator can look into this.
Message 13 of 21
Thank you 😊
Message 14 of 21
Agree if it's the same area code, it shouldn't change.
Message 15 of 21
Its normal for a new line to be given number to start with, otherwise the order cannot progress, as there would be two lines with the same number, which cannot happen.
Once the new line is working, it should be possible to re-number it back to your original number.
Message 16 of 21
Thank you, sounds promising 😊
Message 17 of 21
Welcome and thanks for your post @Richard205207
Sorry for the confusion around keeping your phone number when moving home.  There should be no reason why you can't keep your original number.  What date does your services move over?  Your best bet would be to contact us after the services move over about changing to the number you've been using.
Thanks,
Robbie
Message 18 of 21
8 December is date. Thank you
Message 19 of 21
@Richard205207
Has this now been resolved?
Message 20 of 21
Yes my old number was transferred 😊
