Message 1 of 6
Unable to call ..
Continuing my parents phone saga, they have in theory been given thier original number back. If I try & call it from my landline it comes back as number not recognised, if however I call it from my mobile it goes straight through. Any guesses ? Cheers Pete
5 REPLIES 5
Message 2 of 6
Re: Unable to call ..
Hi @Duchy   Firstly just checking that you are using the full number including the STD code. Who provides your landline?
Message 3 of 6
Hi i can confirm full number Including dialing code used on both - newly changed from Plusnet to BT,
Message 4 of 6
Hi @Duchy   So you are calling from a BT landline to a BT landline and it is not working.
Message 5 of 6
Hi my landline is Plusnet my folks BT & my mobile EE
Message 6 of 6
Hi @Duchy.
I'm glad to hear that the landline number is back, but it definitely needs to be checked out a little more to see why you can't connect to it from your landline. If you get in touch with our tech team, they'll be able to take a look for you.
Michael
