Message 1 of 9
Vulnerable customer
My elderly mother has a fault on her landline
she needs this as she lives alone and uses a lifeline alarm in case of emergency
she cannot use a mobile
I have reported the fault using BTs automated system but how can I let them know how urgently she needs this fixed
8 REPLIES 8
Message 2 of 9
Re: Vulnerable customer
Call customer services  on 0330 1234 150
Is she registered with BT as a vulnerable customer?
Message 3 of 9
Thanks but I’ve already done that it just guides you to the automated system
Message 4 of 9
You should be able to speak to someone on that number.
Message 5 of 9
No they send a text
Message 6 of 9
This needs to be raised as an emergency welfare case with BT. Openreach will then arrange to attend the same day m
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 7 of 9
@JoFord if you don't select any options, you will get to speak to an advisor.
Message 8 of 9
Thanks I think I’m making progress now
Message 9 of 9
Hi @JoFord and thanks for posting.
I've dropped you a private message if you need help. Just reply to that.
Cheers
David
