Message 1 of 3
When to activate the phone?
Hi,
I've just received my Smarthub2 and alexa phone.  I've set up the hub, when do I set up the phone and disconnect the old one, is it after the Digital Voice is activated (at the moment my old phone is plugged into the filter).
TIA
2 REPLIES 2
Message 2 of 3
Re: When to activate the phone?
Message 3 of 3
Better waiting until DV is activated. You can check by going to hub manager and you will see your phone number and then setup phone when you see number active
