Message 11 of 25
Re: Why do BT keep closing my complaint?
It is a combination of both.
Phone on old line....internet through new digital router ... digital being connected 20 October... reported phone issue 30 September.
All equipment in home is working ok.
There is no dial tone.
I have written to BT customer service and will see what happens on 20 October.
Anonymous
Not applicable
Message 12 of 25
What do you mean by "digital router"? If you've been upgraded to FTTP & you router now connects to a newly installed ONT, then your phone service is almost certainly now DV.
Connect to the router via  a browser (192.168.1.254) & check if the phone section is active & showing your number. If so, your phone should be plugged into the back of thee router as @iniltous suggested.
Message 13 of 25
I changed over to a smart hub 2 which I understand has the digital workings installed.
I have the digital phone kit but not connected as been told digital will not be activated till 24 October (not 20 as said in last post, my error sorry).
Message 14 of 25
Checked status results.
Broadband connected
Phone not configured
Message 15 of 25
Presumably then you are currently on PSTN telephony ( phone in wall socket but not working ) , because of your  imminent migration to DV you have been sent a SH2 which you have connected, it shows that DV hasn’t yet been configured, so the PSTN wall socket should still be working ( but isn’t ) .
Obviously I’ve no idea what you have reported, but it should have been that your phone ‘line’ wasn’t working ( NDT , no dialtone )  but your broadband is fine , and reported as a phone problem not a broadband problem, if that was done , it’s possible the migration to DV has been assumed to be the issue when it’s probably the  PSTN exchange equipment that’s faulty ( one of the reasons for moving to  DV is the PSTN exchange equipment is now very old and prone to failure  ) .
A ‘BT’ engineer is actually the correct ‘department’ in that Openreach are not responsible for PSTN equipment ( the actual switch in the exchange building )  but the home visit by BT seems bizarre, nothing can be fixed by BT in your home if you are still PSTN , an exchange engineer visiting a house is nonsensical, suggesting although BT , they were not a PSTN switch engineer .
 The appropriate response to NDT reports, is Openreach check from the customer to exchange and if the exchange at fault , ( your individual line circuit ) it  is not repaired ,  you are transferred to spare , adjacent ( but working ) line circuit by Openreach , ( who call BT , get BT to reconfigure your appearance in the exchange equipment to a new line circuit location and Openreach ‘rejumper’ your line to that new circuit )
Given the fact that it’s now less than two days to the DV changeover , it’s probably pointless attempting to get this resolved now , simply wait until 24/20/24, chances are DV will work and the faulty PSTN is never going to be reissued to anyone , obviously you move your phone instrument to the router from wall socket , once done , ( and working on DV ) ask BT about compensation.
Message 16 of 25
You are spot on iniltous, had another BT engineer round yesterday this was in response to my long telephone call 11 October when was told I would be contacted within 24 hours, he had better luck when contacting office.
It has always been about phone faults no dial tone or very bad line. Interesting your comments on openreach and exchange fault, last time (year ago ish) openreach repaired phone line then said there was a fault at the exchange which was down to BT, never heard anymore and lived with issue.
Anyway the conclusion now is that phone line was disconnected by BT on 9 October before digital was up and running. Expect a post from me Friday 25 saying all is working.
Also had email from BT given me refund for not being able to fix issue within 2 working days.
Message 17 of 25
Update 25 October....Was hoping to say all is working but unfortunately nothing has changed, have landline plugged into the hub nothing, attached BT digital handset nothing.B
Anybody know if BT send an email when digital is turned on?
Message 18 of 25
Was it BT or Openreach that visited on the 23rd ?, seems unfathomable to me that BT visited you , anyway it’s still quite early to be saying the migration to DV hasn’t worked ( that’s not to say it definitely will ) but it may be anytime on the day they said , so could be  23.59pm today ….you obviously know how to check the SH2 stats to see if DV shows as configured, that’s the place to check , but in the interim as your master socket has no dialtone , connect your phone to the router and periodically check …..I can’t recall getting an email saying the migration was done , but I didn’t immediately connect my SH2 ( I continued to use the old BT router ) and did receive a communication ( text or email ) saying we noticed you haven’t connected you new router yet , and to connect it ASAP .
Message 19 of 25
It may also require a reboot of the hub to kick DV into life.
Message 20 of 25
Done reboot no change.
Account is saying "Please connect your new Hub, otherwise there will be a delay to setting up your Phone service." It has been connected since 11 and rebooted 5 minutes ago.
No dial tone on handset say no internet.
Landline no dial tone.
"Fri 1 Nov 2024
Parallel Phone Service
You’re currently in the process of switching from your old landline to your new Digital Home Phone service."
Does this mean  changed over will be next month?
