Message 1 of 4
Will the CX300 R2 work with BT HUB 2 DIGITAL VOICE
Will the CX300 R2 work with BT HUB 2 DIGITAL VOICE. I will need to plug it in to the USB port?
3 REPLIES 3
Message 2 of 4
Re: Will the CX300 R2 work with BT HUB 2 DIGITAL VOICE
Message 3 of 4
It won't work with Digital Voice. I presume you already have a VoIP service that you use the CX300 with. You can continue to use that service.
Message 4 of 4
