Message 1 of 3
digital voice messages
OK BT have moved me to digital voice landline - I had no choice.
They then supplied an adaptor so I can plug my old (Panasonic) handset and yes it rings, Here is the problem. Previously after 6 rings it went to handset messages, and on returning home the handset beeped - new message. Which worked brilliantly.
What I want is not to use 1571 as I don't bother looking at my phone on return and have no idea if I have a new message - I get about 2 a week btw so it's not intuitive to check 1571.
So it is significantly worse and more tedious.
When someone calls the cursed new digital voice, how do I set it to ring 6 times then pass over to the really useful handset, leave a msg and flash and bleep on my return. Like it used to. IT WORKED!
2 REPLIES 2
Message 2 of 3
Re: digital voice messages
You need to go to MYBT and set the dv1571 to answer on more rings than your. Current Panasonic. That way should be back to how it was
The DV FAQ will help you
https://community.bt.com/t5/Home-phone-including-Digital/Digital-Voice-FAQs/td-p/2207485
Message 3 of 3
@peterp2
Or simply do it by calling 1571 & taking option 4.
