Message 1 of 4
digital voice
Hi
Hope you can help. I have a Smart Hub2. I have just received a digital voice phone from BT. Before I pair it with the hub I need to know if that will affect the current  hardwired ports. The "Phone" port is wired to a Careline (with pendant) device which is then hardwired to a dectphone base with 2 auxiliary phones (dect connected)  If I pair the digital voice phone with the hub I need to be sure that the Careline device will still be connected and that my dect phones will also continue to work. Screenshot 2023-12-20 175804.png
3 REPLIES 3
Message 2 of 4
Re: digital voice
Message 3 of 4
Re: digital voice
It won't have any affect at all.  I use a mixture of Digital Voice handsets, with a Dect base station and corded phone connected to the hub socket.
Message 4 of 4
Re: digital voice
Thank you, I dreaded the thought that pairing the digital phone would shut off my careline and dect phones.
cheers
