Message 1 of 4
landline and broadband
Hi
I have fibre broadband and a landline  number. Am i able to port the landline number  to a 3rd party and retain the broadband ?
3 REPLIES 3
Message 2 of 4
Re: landline and broadband
Do you mean a third party analogue voice provider or VoIP provider?
Message 3 of 4
An analogue provider.
Message 4 of 4
Then no, it is not possible.
If you are trying to avoid moving to a VoIP solution (either BT's Digital Voice or third party VoIP) you are wasting your time as all analogue services will switched off by 2025 in any case.
