Message 1 of 8
Asus DSL-Ax82u router help??
I am trying to set up the Asus DSL-Ax82u router with BT fttc.
I bought it so I don't have to use the modem. I have plugged it in as the guide states and reset it but it still won't connect to even the Asus router page. I have tried using the BT modem and it still won't connect.
Can anyone help me with this please?
7 REPLIES 7
Message 2 of 8
Re: Asus DSL-Ax82u router help??
you need to set username to
[email protected]
password anything many just use BT
Message 3 of 8
The router just says 'no internet access '
Message 4 of 8
https://community.bt.com/t5/Home-setup-Wi-Fi-network/Replacing-BT-Smart-hub-2-with-Asus-DSL-ax82u/m-...
Anonymous
Not applicable
Message 5 of 8
 https://community.bt.com/t5/Home-setup-Wi-Fi-network/Replacing-BT-Smart-hub-2-with-Asus-DSL-ax82u/m...
Also make sure you use the RJ11 cable that came with the router & not the one from the BT modem.
Edit: Too slow. 😁
Message 6 of 8
Could also try setting vlan to 101. Hope that helps
Message 7 of 8
@jazzy64
that is covered in the links already posted
Message 8 of 8
Yeah just seen it mate apologies
