Message 1 of 7
BT Broadband / Netgear Nighthawk XR1000 Issues
Good morning all. I’m hoping for some advice. I have upgraded to full fibre 500 with BT and have the netgear nighthawk xr1000. It appears to be working in some fashion but the speeds are fluctuating alot. I have plugged the nighthawk directly into the small box fitted to the wall (pic attached) by the installer. Does this box act as a modem or is this what’s causing my problems I have read online that people are suggesting you get a BT OPENREACH HG612 modem and connect this between the box on the wall and the nighthawk router. The dumaOS is also coming up with errors and i am wondering if this will resolve the issues. Any advice welcome. Thanks in advance.
6 REPLIES 6
Message 2 of 7
Re: BT Broadband / Netgear Nighthawk XR1000 Issues
That 'box' is an Openreach optical modem (ONT) which you just connect your Netgear directly to. The HG612 is a copper modem for VDSL lines and is not required.
Message 3 of 7
Thanks for the heads up. So I don’t need anything else between the ont box and the router? Not sure why the dumaOS is showing errors on geo filtering and the speeds fluctuating.
Message 4 of 7
Correct
No idea, I'm afraid
Message 5 of 7
Thankyou for taking the time to reply. Much appreciated. I am going to make contact with netgear later today but wanted to check regarding the modem first.
thanks again👍🏻
Message 6 of 7
You will get speed fluctuations as you are sharing your backhaul connection with other users, you do not have your own personal uncontended connection.
Message 7 of 7
I understand that some fluctuations are normal but this is going from 90mb/s to 500mb/s then back to 120mb/s then 250mb/s and so on. Seems erratic to me. Thanks
