Message 11 of 24
Re: BT Full Fibre 900 + Asus Mesh Home Network
No, and even if it did you wouldn't be able to access DV as a device in bridge mode doesn't have access to the IP layer.
Message 12 of 24
OK Thanks.
@licquorice What would be the configuration then to allow the use of BT Voice using the SH2, keeping the main asus router as the DHCP server and not having double NAT's?
Message 13 of 24
You can't, you will have to double NAT.  If you put the Asus in the DMZ of the SH2 you won't be double port forwarding.
Message 14 of 24
you cant sh2 as got to be mains Hub if you want DV
Message 15 of 24
WOW, I'm surprised BT went down this route with a flagship product.
I don't know why the didn't go with a simple VOIP solution.
But I guess with Mobile phones more and more private homes are doing away with voice land lines anyway.
My son is an avid online gamer so double NAT's is not an option.
Message 16 of 24
you would been better getting new EE and there QOS system
Message 17 of 24
Because its not secure enough, the origin of the call needs to be fully verified.
Message 18 of 24
Have you tried it?
Message 19 of 24
No I haven't, but I have read alot about it causing problems.
Message 20 of 24
Don't believe everything you read. I can't say either way as (a) I'm not a gamer and (b) I only use one router, but I would try it for myself before passing judgement.
