Message 1 of 2
BT Hub 2 setting
Hi
I have a BT Hub2, i keep getting drops wifi/braodband.  I have copper Gfast connection via the DSL port on the hub, BT Halo3 Fibre 100.  Just looking at the settings in the hub under broadband and I see that Full Fibre (FTTP) Mode is turned on, should this be off given i dont have a fibre connection.
1 REPLY 1
Message 2 of 2
Re: BT Hub 2 setting
you can turn it off as all it is doing is making ethernet port 4 a Wan or LAN port
