Message 1 of 3
BT Mini Connector
Hello,
I have a set of BT mini Connectors, when all linked together with ethernet cables (Hub to Mini Connector 1, to Mini Connector 2, to Laptop) the ethernet connection comes thru just fine!  The problem is when I take away the ethernet chord between the two Mini Connectors, mini connector 2 loses its ethernet signal (the connectors are plugged in next to each other so I am confident they are on the same circuit).
I have factory reset them and am confident they are paired correctly.  Is there other options I can try to ensure the ethernet is being sent via the circuit correctly?
Thank you in advance
2 REPLIES 2
Message 2 of 3
Re: BT Mini Connector
That would imply there is some form of interference in your mains wiring.
Message 3 of 3
Hi @brockoli and welcome to our community.
Thanks for posting about your mini connectors. I'd have to agree with @licquorice on this. The symptoms you're describing would point to an internal wiring issue.
Cheers
David
