Message 11 of 18
Re: Cable connection
@Anonymous  That looks like the old interstitial plate.  I believe the Mk2 and 3 iplates could take an RJ45.  I'm not sure about the Mk1.
Message 12 of 18
If I cut the cable then simply reconnect it by twisting the bare wires would that work?
Message 13 of 18
Trying to tap into the knowledge base…
Message 14 of 18
Thanks for that. If I search for ‘RJ45 to RJ11 cable’ would that be correct?
Anonymous
Not applicable
Message 15 of 18
Yes. I've found an Ebay seller with 100% feedback with a 0.5m one for £3.49 but can't link directly. Search Ebay for item 251690246370.
Cutting the cable would be a bad idea.
Message 16 of 18
This one?
Anonymous
Not applicable
Message 17 of 18
Yes.
I've no direct experience with the seller but his feedback indicates it should be safe purchase. Although there's probably little, if anything, to be gained from changing to a shorter cable other than aesthetics.
Message 18 of 18
aesthetics Is all 😊
thanks for your help.
