Message 1 of 18
Cable connection
I have a wireless router connected to the BT socket on the wall by a cable which is approx 6 metres log. I keep it coiled up as the distance between the router and socket is only about 500mm! Can I get a shorter cable of shorten the current one?
17 REPLIES 17
Anonymous
Not applicable
Message 2 of 18
Re: Cable connection
Yes.
If you have FTTP with an ONT then you need a Cat5e or better RJ45 ethernet cable. If you have a copper based service with a master socket then an RJ11 cable.
Message 3 of 18
What is FTTP with an ONT?
Message 4 of 18
I think I have have a copper based service
Message 5 of 18
If that is the case, it must plug into the DSL port on the BT Home Hub, and then connect to your phone socket. Is that correct?
Message 6 of 18
Can I post a picture?
Message 7 of 18
Yes use camera icon
Message 8 of 18
Anonymous
Not applicable
Message 9 of 18
Slightly trickier as the Fritzbox uses an RJ45 for the DSL connection. So you need  an RJ45 to RJ11 cable. Might be tricky to find one short enough.
Message 10 of 18
@Inkedwood
That is not a BT Home Hub, are you a BT Broadband customer, if not, why are you posting on this forum?
