Message 1 of 3
Cant access BT Premium Whole Home WiFi Web Portal
I have 3 BT Premium Whole Home WiFi discs. When I first installed them, I could access the web portal, view my network etc. ( http://btwhole.home ).
I recently unplugged/disconnected them all for a short period of time.  Now they are reinstalled, all connected, all blue, all working fine. However, I can no longer access the web portal.  I have forgotten the SSID on my devices, switched off the wifi, reconnected anew and have not changed any settings on my PC. I continue to get this error message. Any ideas?
This site can’t be reached
Check if there is a typo in btwhole.home.
  • If spelling is correct, try running windows network Diagnostics.
DNS_PROBE_FINISHED_NXDOMAIN
2 REPLIES 2
Message 2 of 3
Re: Cant access BT Premium Whole Home WiFi Web Portal
What router are you using?
I've had similar problems with the SH2, try powering it down for about 30 seconds or so before powering it up again.
Also make sure so-called 'Smart Setup' is disabled, it's really not that smart and can cause lots of problems.
What is Smart Setup on the BT Hub? How can I turn it on and off? | BT Help
Message 3 of 3
Thanks - However I have tried all of this... and it didn't help for the Whole Home WiFi discs....
