OK thanks....but I cannot see any reason to make that feature unavailable in the new hub
I am now with EE but had big problems with their hub (not allowing traffic through the ethernet ports) so they kindly sent me a BT hub which works fine....except for this issue
I'm sure I changed the name of devices through my new fibre hub since it arrived, I definitely did it on the old Smart Hub 2
I can do it through the EE App, but oddly the App is showing only one Ring device (and it was one of those I first changed through the app) but the desktop manager is showing two - camera/doorbell and chime
it seems i can do this in the app but no longer on pc web access
w h y ?????
Hi again, @davidwf15
I've had this double checked, and for the Smart Hub 2 it's the Hub Manager to change device names.
Our newer hubs are much better at correctly identifying what kind of device is being used, but if you wish to give it a custom name, this would be via the app instead.
Peter
Thank you
Some devices are correctly displayed, the ones I changed on the app still show incorrectly on the web page...
Well it doesn't on mine 😒
@davidwf15 Sometimes it can take a bit of time for the Hub Manager and app to communicate with each other and update.
If you haven't already, I'd recommend renaming one of the devices that hasn't updated to something else, then change it back to what you originally wanted.
Often this can force through the update.
Peter
Cheers @davidwf15, I'm glad to hear that's updated for you now 😊
Peter
