Message 1 of 10
Dreytek 2860n setup
Hi all,
I have purchased a dreytek 2860n router for home use. I have contacted BT Support to get static IP address, subnet and default gateway details so it can talk back to BT but have not been able to assist. How can I obtain these details to complete my setup?
9 REPLIES 9
Message 2 of 10
Re: Dreytek 2860n setup
@TechGuyy
Only BT Business customers get a static IP address.
If you are a BT Business customer, then you will need to ask on that forum,
https://business.forums.bt.com/
This is the residential forum.
Message 3 of 10
I don’t fancy moving to Business BT. It’s a setup for my home for test purpose. So what other ways are there to getting dreytek working with internet?
Message 4 of 10
@TechGuyy
Its not possible to get a static IP address.
Message 5 of 10
Ok.
what other way is there to set up dreytek router so I can get internet to work from it?
Message 6 of 10
Configure the PPPoE credentials with the generic username of [email protected] and password BT.
Message 7 of 10
Do you have FTTC or FTTP?  Are you intending continuing using hub as well or is dreytek to replace hub.  If you have digital voice then your need to use hub
Message 8 of 10
I have fttp.
Only going to use dreytek to replace BTHub.
Message 9 of 10
Then use username as posted by @licquorice
Message 10 of 10
I’ve tried this and it did not work.
I’ve enabled PPoE and added
username: [email protected]
password: BT
