Message 1 of 4
Dropping wifi speed
Hi all , I have recently bought a new build house with fttp installed upstairs in a cupboard that's where my bt hub 2 is,  and patch sockets  and ont box ect, I took out a 2 year  contract 150 mgbs a month and was upgraded to 500mgbs for the 1st month, great but every other day I have to reboot hub as when I test WiFi speed on my mobile I'm only getting 50mgbs, then after re boot, hey presto full 500, why  should I pay extra for the 500 if I have ro constantly have to re boot, tried re set , on off on the router , on and off at plug, different times of day testing nothing even attached to Internet as not moved in yet , why should I pay for something I'm not getting.
3 REPLIES 3
Message 2 of 4
Re: Dropping wifi speed
Try switching off smart set up on the hub.
And bear in mind of course the speeds achieved over wifi will depend on distance from the hub and the features of your phone.
BTW when you say "150mgbs a month" are you receiving to the download speed and NOT some sort of data allowance?
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings icon. If someone answers your question correctly please let other members know by clicking on ’Mark as Accepted solution’
Message 3 of 4
I was infront of hub , and my mobile as most will test up to 200 mgbs ect also it goes up to 200 when rebooted,  can I ask whot is smart set up and how to disable it thanks in advance.
Message 4 of 4
Log in to the hub  = you should see this. If smart set up is on, switch it off.Screenshot 2022-03-27 at 14.23.02.png
