Message 1 of 7
Extending WiFi into the stable yard
I have BT halo with 3 discs to overcome internal house transmissions due to high metal content in the walls (1930s slag bricks). I need to extend WiFi coverage to the tac room in the stables. I get some coverage outside the house but not as far as I need.  I don't believe I can add another extender, is it possible to run an ethernet cable from the BT hub and put a stand alone router on the end to give me the coverage I need? This will obviously not be a BT device, will it interfere with the WiFi from the BT system? Any help/advice would be greatly appreciated.
6 REPLIES 6
Message 2 of 7
Re: Extending WiFi into the stable yard
Yes, you can do that but you don't need another router a simple wireless access point (wap) will suffice. To avoid any possibility of interference, set the device to a different channel to the main system.
Message 3 of 7
Thank you for that, I'm not aware of waps, any suggestions as to where I can get one?
Message 4 of 7
All the usual sources.
Try Google
Message 5 of 7
TP-Link EAP725-Outdoor WiFi 7 Access Point (5Gbps BE) OK?
Message 6 of 7
Yes, but probably overkill for your requirements.
Have a look at
https://www.tp-link.com/uk/home-networking/access-point/tl-wa1201/
Or the EAP 235
Message 7 of 7
Thank you for your help, I’ll give it a go and see what happens
