Message 1 of 3
Fibre
Is the old fibre providers line used to bring in BT broadband from the pole or a separate one installed
2 REPLIES 2
Message 2 of 3
Re: Fibre
Depends if old and new are both Openreach provided.
Message 3 of 3
Re: Fibre
Eh?
Are you asking if Openreach will use an Alt Nets Fibre Drop Cable to Cut & Draw their own Fibre Cable?
If so then the answer is no. Openreach can’t remove other Alt Nets Wiring and or Equipment and neither can the Alt Net remove Openreaches.
