Message 1 of 6
WiFi disc!
Help please!!
im trying to set up a BT WiFi disc!
so i need to plug in a Ethernet cable from our router to the disc, is this cable meant to be supplied with the disc or not?
if not where am I meant to get one from?
5 REPLIES 5
Anonymous
Not applicable
Message 2 of 6
Re: WiFi disc!
From memory no ethernet cable comes with the WiFi discs.
Amazon for around £4
Once you have one really easy to set up through the app.
Message 3 of 6
Re: WiFi disc!
Hey there @Kim2803.
Thanks for reaching out to us here on the Community!
As @Anonymous has mentioned, there's no ethernet cable provided with the WiFi Disc itself, but there is one included with your main Hub.
You can find a setup guide with all the details you need right here on our YouTube channel.
Peter
Message 4 of 6
Re: WiFi disc!
We’ve had our smart hub for a few years now so no longer got anything that came with it
Message 5 of 6
Re: WiFi disc!
Thank you
I’ll have to purchase the cable, I’m ok with setting it up, it’s the cable that’s thrown me 🤣🫣
Anonymous
Not applicable
Message 6 of 6
Re: WiFi disc!
Ask around someone's bound to have a spare one
I've about 6 of the buggers in the obligatory draw with all the cables in.
