Message 41 of 82
Re: Help! BT blocking a website i was building!
Well done Charlie or whoever, the site is now working (at least via Cloudfare)
Message 42 of 82
bit rude aren't you. I was stating that a new router has now been delivered, which i'd arranged before i'd even used this forum. thinking it maybe faulty.
Message 43 of 82
I've no idea how it was flagged to be honest but it was from the National Cyber Security Centre.
We've raised a false-positive report
Steve
Message 44 of 82
Thank you Steve,
I still don't see the site, but presumably it will take some time to propagate?
Message 45 of 82
Hi Steve,
I still can't load it, just tried a nslookup and have this:
PS C:\Users\shelt> nslookup www.mattyedgell.com
Server: bthub.home
Address: fe80::e675:dcff:fe4c:69d4
*** bthub.home can't find www.mattyedgell.com: Non-existent domain
Message 46 of 82
Just change your laptop/PC/Mac to Cloudfare DNS 1.1.1.1 and you will be able to access the site.
Message 47 of 82
As @licquorice  says, if you are in desperate need of it, you can change your DNS server.
This is the first site I've seen blocked via this method so can't give any promises on propagation times sorry.
Hopefully you've got some reassurance that the issue is being taken seriously though.
If it's not back by tomorrow then give me a prod 🙂
Steve
Message 48 of 82
OK thanks, just didn't know how long it'd take.
Started making sites when I was 15, i'm now 43 and I've never had this before either!
Appreciate everyones help looking into it. Was a long road and many people jumped in, so thank you. I'll check tomorrow.
Message 49 of 82
It's back!
I had a phone call with Charlie, who said it's back and he's added it to a white list so shouldn't happen again, but he will investigate as to why it happened and feed that back to me.
Thank you Steve, Charlie and you two guys for helping investigate - it's driven me nuts all week!
Cheers
Message 50 of 82
We've had a very similar issue with people not being able to access a site via BT (and possibly EE), the DNS is not resolving. The domains are https://exp.uk.com , https://rebeccasymons.exp.uk.com/  and other *.exp.uk.com domains. This stopped last week. I have checked spam lists for the IP and domain name and nothing is listed. Looks very similar issue. Any chance looking into this?
Many thanks
