Message 51 of 82
Re: Help! BT blocking a website i was building!
Will do
Message 52 of 82
Sorted 🙂
Message 53 of 82
What's happening Steve, why are people suddenly getting these issues? have BT changed some security features or something that's had a knock on affect?
Message 54 of 82
I'm asking the same questions but this was blocked for a different reason from a different source so just coincidence this time.
Steve
Message 55 of 82
Thanks Steve. Was was the cause of this?
Message 56 of 82
I seem to be facing a similar issue as others have mentioned in various threads on here.
My site that i've recently been working on was working fine untill about a week ago were people with BT as their isp have no longer been able to connects despite myself and others being fine and all dns checks not flagging anything. https://scottishdesign.directory/
Why does this seem to be hitting so many different people.
Contacted the BT saferbrowsing email multiple times to no response.
Message 57 of 82
I can’t say in detail what the issue is, in a public forum, but I think I’ve got to the bottom of it, have some new friendly contacts and will keep an eye on it until I’m happy.
Ultimately we are trying to keep us all safe from scams, malware and malicious actors. There is a balance to be had which we’ll find
Steve
Message 58 of 82
Hi @Steve_M - Is there a way of raising domain issues like this? We are having an identical issue with the domain lnk.ie where it is not resolving via BT/plusnet but does from any public DNS service. Unfortunately going via the normal help routes just leads to them trying to factory reset smart hubs and then claiming there isn't an issue when there clearly is one. Thanks
Message 59 of 82
Always happy to take a look. What are you seeing?
For me it looks fine using nslookup:
> ink.ie
Server: 81.139.56.100
Address: 81.139.56.100#53
Non-authoritative answer:
Address: 23.227.38.32
> server 81.139.57.100
Default server: 81.139.57.100
Address: 81.139.57.100#53
> ink.ie
Server: 81.139.57.100
Message 60 of 82
Thanks for getting back to me @Steve_M . The domain is lnk.ie not ink.ie (L not an i) Thanks
