Message 1 of 4
Home Hub 2 ports
Hi all!
Been having issurs lately with my home hub flashing purple on an evening.
Only way I can get back online is by powering off and on!
I read on here about only using port 1 on the smart hub 2.
Is this correct?
I am currently using 3 ports, and wondered if this could be the issue??
Thanks in advance!!!
3 REPLIES 3
Message 2 of 4
Re: Home Hub 2 ports
with SH2 you can use all 4 ports but port 4 doubles as WAL/LAN for customers on FTTP who use as WAN via a toggle switch in hub advanced settings
if still problems then I would try factory reset using recessed button on back and pressing/holding for 20/30 secs until hub lights flash
Message 3 of 4
Thanks imjolly,
Would you recommend just using ports 1 - 3 then?
Also, not to sound too stupid, but what do you mean by 'WAL/LAN for customers on FTTP who use as WAN' - I am not very technical!!!
Message 4 of 4
if you are on FTTP - fibre to the home then there is a white modem - ONT - installed and your hub connects to that using ethernet cable and must connect to port 4 as WAN not lan port.  you can use all ports as long as not on FTTP
