Message 11 of 14
Re: How do I get a domain removed from BT DNS blacklist?
@creativelink this site is also blocked by Sky for containing malware and spyware
Message 12 of 14
I have just checked and Avast and Malwarebytes blocked your original site.
No issues with the second one you posted.
Message 13 of 14
This is a total nightmare!
I'm completely stuck on what to do. Have any of you experienced this before? I don't know who to contact now if you believe it's not a BT problem.
I can access the site fine via 5g so I'm thinking the domain isn't completely blacklisted.
Any help or guidance is really appreciated.
Message 14 of 14
@creativelink any luck with this?
Our domain (gamma.app) is having a similar issue. DNS doesn't resolve at all.
➜ ~ dig gamma.app @ns0.bt.net
; <<>> DiG 9.10.6 <<>> gamma.app @ns0.bt.net
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: REFUSED, id: 6677
;; flags: qr rd; QUERY: 1, ANSWER: 0, AUTHORITY: 0, ADDITIONAL: 1
;; WARNING: recursion requested but not available
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 4096
;; QUESTION SECTION:
;gamma.app. IN A
;; Query time: 142 msec
;; SERVER: 217.35.209.188#53(217.35.209.188)
;; WHEN: Tue Mar 05 20:08:12 PST 2024
;; MSG SIZE rcvd: 38
