Message 1 of 7
How do I terminate this 4 core cable?
They have not terminated the cable on our property due not having a building present at the time. I want to terminate it now to plug it in a Smart Hub for internet and VoIP connection.
What is the color layout order, it is not the standard CAT6 colour code. See photo below:
6 REPLIES 6
Anonymous
Not applicable
Message 2 of 7
Re: How do I terminate this 4 core cable?
It's anyone's guess what that cable is or where it goes. You need to order a service from an ISP who will then arrange any necessary connections. A new build would normally be FTTP unless there's no provision in the area.
Message 3 of 7
The cable goes to BT's cabinet on the pole adjacent to the property.
Message 4 of 7
the cable if going straight to pole is property of openreach.  are you a BT customer?
Message 5 of 7
Yes, we are BT customers.
Message 6 of 7
then you need to contact CS 03301234150 and get visit from openreach to connect up your broadband
Message 7 of 7
Thanks, called them out.
