Message 1 of 7
NAT Type PS5
Hello BT, I have a Smart Hub 2 router and I am trying to achieve a NAT Type 1 on my PS5. I have already assigned a static ip address on my PS5 and therefore, added these ports to open:
Tags (2)
6 REPLIES 6
Message 2 of 7
Re: NAT Type PS5
As you are on a 192.168.x.x network you are highly unlikely to achieve a NAT type 1.
Have a read: NAT Types: Network Connection Quality (portforward.com)
Message 3 of 7
Re: NAT Type PS5
Not being a gamer, I have no idea why the gaming fraternity have a concept of different types of NAT and what the criteria is for each.
NAT is network address translation, it is a mechanism to translate packets arriving at a device with a public IP address and direct them to a device with a private IP address. There are not different types of that process.
Message 4 of 7
Re: NAT Type PS5
How come?
I thought anyone can achieve NAT Type 1.
Message 5 of 7
Re: NAT Type PS5
Did you read the article I posted a link to?
To have NAT type 1 on a PS you effectively have to be directly connected to the Internet, not on a private address. If you are using a router, it would need to be in bridge mode with only your PS connected - not possible with a SH2 (and a bad idea generally.)
Message 6 of 7
Re: NAT Type PS5
I have no idea why game console manufacturers and the gaming community hijack defined terminology and use it for something else.
NAT is NAT, there are no variants.
I have no idea what it is they call NAT of various types.
Message 7 of 7
Re: NAT Type PS5
