Message 51 of 55
Re: IPv6 on TP-Link Archer AX95 with BT Full Fibre
I believe it is something to do with this /56 prefix because even with prefix delegation enabled it keeps flipping from an fe80 to a 20 address and it says /64 on the end, it's totally glitched.
(they just need to allow users to define the prefix instead of detecting it which obviously isn't working correctly).
Message 52 of 55
Nicely spotted, I don't think it'll make a difference, corrected nonetheless.
Message 53 of 55
So I'm actually making some progress, using "non-address" on WAN side and DHCPv6 on LAN side, and a couple of reboots.
One problem however, it's assigning 1 IPv6 Address to 2 devices at a time, (I suspect because of the /56 prefix BT uses and the AX95 still detecting /64).
So only half of my devices are getting IPv6 functionality and able to test on test-ipv6.com 🙄.
TP-Link support is going to try sort it out (we'll see, IMO it needs a firmware update).
Message 54 of 55
I'm just wondering if this will be my next issue: setting a local IPv6 address as the DNS server.. lol
I'm pretty new to IPv6, so I need to set a static on the Pi is what you're saying?
Message 55 of 55
Also, if anybody else has this issue, this is what seems to be working for me at the moment:
it did require a reboot upon updating the settings, otherwise it doesn't work.
I need to keep an eye because it assigned the same v6 address to two devices simutaneously which meant only one of them worked on test-ipv6.com (might be to do with the prefix), will keep an eye and report back.
