Message 31 of 55
Re: IPv6 on TP-Link Archer AX95 with BT Full Fibre
Pretty sure it needs to share the PPPoE
MyNet@gtax6000:/tmp/home/root# ifconfig ppp0
ppp0 Link encap:Point-to-Point Protocol
inet addr:xx.xx.xx.xx P-t-P:172.16.18.229 Mask:255.255.255.255
inet6 addr: fe80::949f:2804:f0f:556e/10 Scope:Link
UP POINTOPOINT RUNNING MULTICAST MTU:1492 Metric:1
RX packets:7044746 errors:0 dropped:0 overruns:0 frame:0
TX packets:1751536 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:3
RX bytes:8791764833 (8.1 GiB) TX bytes:350716797 (334.4 MiB)
The only address in there I need to hide is my own IPv4 address, the gateway is common and the IPv6 local gateway is only reachable from inside my LAN (so mods no need to edit!)
Whole house, garden, garage and half the street covered by a Flint 4 - WiFi 7 router
Message 32 of 55
Yeah, didn't know whether specifying the same credentials separately might work.
Surprised there isn't a setting to define the prefix length anywhere.
Message 33 of 55
Yeah i see the fe80 address on stateless, so I guess that's fine, I'm gonna try rebooting now with the suggestions the other user suggested (Thanks by the way).
Message 34 of 55
So my log is full of this upon hitting the connect button (not restarted yet as people are streaming at the moment).
2023-08-07 22:09:33 PPP INFO [6386] pppoe send PADI Host-Uniq(18f2)
2023-08-07 22:09:33 PPP INFO [6386] pppoe send PADT due to(resending PADI)
2023-08-07 22:09:28 PPP INFO [6386] pppoe send PADI Host-Uniq(18f2)
2023-08-07 22:09:28 PPP INFO [6386] pppoe send PADT due to(resending PADI)
2023-08-07 22:09:17 PPP INFO [5614] pppoe send PADI Host-Uniq(15ee)
2023-08-07 22:09:17 PPP INFO [5614] pppoe send PADT due to(resending PADI)
2023-08-07 22:09:07 PPP INFO [5614] pppoe send PADI Host-Uniq(15ee)
2023-08-07 22:09:07 PPP INFO [5614] pppoe send PADT due to(resending PADI)
2023-08-07 22:09:02 PPP INFO [5614] pppoe send PADI Host-Uniq(15ee)
2023-08-07 22:09:02 PPP INFO [5614] pppoe send PADT due to(resending PADI)
2023-08-07 22:08:51 PPP INFO [4618] pppoe send PADI Host-Uniq(120a)
2023-08-07 22:08:51 PPP INFO [4618] pppoe send PADT due to(resending PADI)
2023-08-07 22:08:41 PPP INFO [4618] pppoe send PADI Host-Uniq(120a)
2023-08-07 22:08:41 PPP INFO [4618] pppoe send PADT due to(resending PADI)
2023-08-07 22:08:39 Network INFO [4289] Connect interface internetv6
2023-08-07 22:08:39 Network INFO [4289] Connect interface wanv6
2023-08-07 22:08:36 PPP INFO [4618] pppoe send PADI Host-Uniq(120a)
2023-08-07 22:08:36 PPP INFO [4618] pppoe send PADT due to(resending PADI)
2023-08-07 22:08:34 Traffic Statistics INFO [11293] stats reset
2023-08-07 22:08:34 Network INFO [4289] Reload config
Message 35 of 55
Do those PPP entries stop if you go back to share with IPv4?
Its trying to create a PPPoE session and failing, perhaps because you have an IPv4 session already.
Message 36 of 55
They do stop, and it shows me a fe80 address for IPv6 under WAN after a reboot.
devices don’t get a 2020 address or any ipv6 address for that matter now and it’s constantly looping my NAT/ portforwarding and esssntially breaking it.
I’ve disabled IPv6 for now, I suspect it’s TP-Link not supporting the 56 prefix as others have reported 🙄
2023-08-07 22:39:15 NAT NOTICE [29356] Virtual server created succeeded[ex-port:27367 ip:192.168.1.171 in-port:32400 protocol:tcp]
2023-08-07 22:39:13 Remote Management INFO [30163] Service stop
2023-08-07 22:39:12 NAT INFO [29356] Initialization succeeded
2023-08-07 22:39:11 NAT INFO [29356] Initialization succeeded
2023-08-07 22:39:10 NAT NOTICE [28403] Virtual server created succeeded[ex-port:27367 ip:192.168.1.171 in-port:32400 protocol:tcp]
2023-08-07 22:39:07 NAT INFO [28403] Initialization succeeded
2023-08-07 22:39:06 NAT INFO [28403] Initialization succeeded
2023-08-07 22:39:06 Remote Management INFO [28560] Service stop
2023-08-07 22:39:01 NAT NOTICE [25695] Virtual server created succeeded[ex-port:27367 ip:192.168.1.171 in-port:32400 protocol:tcp]
2023-08-07 22:38:58 UPnP INFO [26782] Service stop
2023-08-07 22:38:58 NAT INFO [25695] Initialization succeeded
2023-08-07 22:38:57 NAT INFO [25695] Initialization succeeded
2023-08-07 22:38:57 Remote Management INFO [26360] Service stop
2023-08-07 22:38:54 NAT NOTICE [24591] Virtual server created succeeded[ex-port:27367 ip:192.168.1.171 in-port:32400 protocol:tcp]
2023-08-07 22:38:51 NAT INFO [24591] Initialization succeeded
2023-08-07 22:38:50 NAT INFO [24591] Initialization succeeded
2023-08-07 22:38:50 Remote Management INFO [24951] Service stop
2023-08-07 22:38:49 PPP INFO [24657] ppp receive IPCP ACK
2023-08-07 22:38:49 PPP INFO [24657] ppp send IPCP Req options(addr=86.-snip-;)
2023-08-07 22:38:49 PPP INFO [24657] ppp receive IPCP NAK options(addr=86.-snip-;)
2023-08-07 22:38:49 PPP INFO [24657] ppp send IPCP Req options(addr=0.0.0.0;)
2023-08-07 22:38:49 PPP INFO [24657] ppp receive CHAP Success: CHAP authentication success
2023-08-07 22:38:49 PPP INFO [24657] ppp send CHAP Response [email protected]
2023-08-07 22:38:49 PPP INFO [24657] ppp receive CHAP Challenge name=acc-aln2.stp
2023-08-07 22:38:49 PPP INFO [24657] ppp receive LCP ACK
2023-08-07 22:38:49 PPP INFO [24657] ppp send LCP ACK
2023-08-07 22:38:49 PPP INFO [24657] ppp receive LCP R
Message 37 of 55
I’m gonna look at returning this AX95 and maybe getting an ASUS, I like this one because it has 8 antennas and 2 5GHz bands, any suggestions?
Message 38 of 55
The RT AC88U seems a popular choice.
Message 39 of 55
So TP-Link support tells me the AX95 is comptible the a /56 prefix.
Still doesn't explain why it won't work on BT for me and other Archer customers...
Absolute nightmare
Message 40 of 55
They told me my 9980 was compatible a few years ago, I could never get that to work either!!
